flickering leds
Posted: Sat Dec 16, 2017 12:22 pm
Hi Guys,
I've a question about my new matrix bord with a lots of led
around 6000 pieces.
When my bord is on the power and the artnet cable is connected to my laptop (2.0.0.1) all of the leds are 'off'. There is no problem with the leds.
When I started the Madrix software with the blackout function, then started the problem with flickering leds...The flickering leds are random and the time between the flickering is random to.
When I run a storage the flickering leds is less, but not complete gone. For this setup I use a artnet controller (2.0.0.41)
I've got another setup with a Luna 16 and I have the same problem there. But this setup haves a lot minder leds.
Both setups I don't use toghether.
What can I do to fix this problem, where to start?
Thanks for you help!
