PLEXUS - using switches to fire different scense
angusmuirdesign
Post by angusmuirdesign »
I am struggling to get my PLEXUS to work on the expansion port.
I have tried all the things in the manual - but still I cannot get it to work.
can you please help :)
Angus
Re: PLEXUS - using switches to fire different scense
Hello Angus,
Can you please explain a little bit what you try to do with the extension port of the MADRIX PLEXUS? Do you want it to use it for input or output?
angusmuirdesign
I want to use it as an INPUT port.
I have the PLEXUS to control the different scenes.
I have a PLC that is going to send a signal to the PLEXUS to trigger different scenes.
I just do not know how to do this or what settings for the plexus.
Thank you
The extension port features 15 individual ports as shown here: http://help.madrix.com/m3/html/plexus/h ... _port.html
Only 6 of the ports are available for analog input (0-100%), while all 10 ports can be used for digital input (0/1, On/Off). 5 of the ports are for power/ground.
In order to configure your PLEXUS, please use the menu "Tools > PLEXUS Configuration...".
When creating a PLEXUS Configuration, a show file to put on the SD card, you then need to make sure to configure the > tab "Extension Ports" as well.
Learn more: http://help.madrix.com/m3/html/plexus/h ... confi.html
There you can define what each of the 10 ports should do.
For example: #1 could be defined as Type - Digital Input, Action - Scene, Value - 1. That means if the PLEXUS receives a digital signal on Port 1 (which physically is Pin 2), it will trigger Scene 1.
angusmuirdesign
If I have a physical switch - can you tell me the exact settings I should have.
I have tried a variety and had no luck.
If it is a simple push button switch that closes the circuit momentarily - how would I set this in the PLEXUS config.
I really appreciate your assistance.
Angus
Hi Angus,
Can you please send us your PLEXUS Configuration to info[at]madrix.com?
Please add a description of the physical switch you are using and which Scene should be triggered.
Thank you for your help!
chalshokhi
Post by chalshokhi »
In order to configure your PLEXUS, please use the menu "Tools > PLEXUS Configuration...". .
When creating a PLEXUS Configuration, a show file to put on the SD card, you then need to make sure to configure the > tab "Extension Ports" as well. ??
_______________
We offer guaranteed success for Testking cissp certification exam with help of latest pmp certification certification and jhu practice questions and the exams of Tabor College
Hello chalshokhi,
Do you need any assistance from us?
