Problem with strobe and pulse
pol@wksound.lu
I have installed Madrix on different PCs/Notabooks, but I always have the Problem that the SCE Pulse/Stroboscope does not Flash regularly, sometimes it flashes very fast, somitimes there is an interval of nearly a second between the flashes. When i turn the BPM Fader down, so that the Flash frequency is very low, it nearly works perfect, but if the frequency is at a normal level for a strobe effect, it dosent work properly. Also the Flash button in the middle near the fader has the same Problem. I Use DVI out. But the Problem comes from the Software, because already the Flash in the preview Screen has the Problem. I hope you can help me.
thank you very much
best regard
pol
thank you very much
best regard
pol
Re: Problem with strobe and pulse
What is the framerate of your previews?
