How to
ERGÜLÖZEYE
How to
İ have been downloaded the Madrix 3.x and i couldnt worked out my pixel mapping hardware. İts (SGM TLD 612a ). is there any solve about this situation. can u give me a step by step solution.
thanks..
thanks..
Re: How to
Hello ERGÜLÖZEYE,
When you want to connect MADRIX with an Art-Net node like the "SGM - TLD 612a" you have to make sure that the MADRIX PC and also all the Art-Net nodes work in the same network.
In the following link you can learn how you connect an Art-Net node in MADRIX:
After MADRIX has found the Art-Net nodes you have to create the patch in MADRIX. In the patch you have to add all the desired fixtures and also the DMX assignment for the added fixtures.
In the following links you can learn how you can create a patch in MADRIX:
