Akai apc40 MK2 ( newest midi for AKAI)
opm128
Post by opm128 »
Any one use the akai apc40 MK2 yet ? I have a feeling the midi mapping might be different then the older version that is posted on this site? if you have used it did you need to install any drivers or any issues or was it just plug and play?
Re: Akai apc40 MK2 ( newest midi for AKAI)
Hello opm128,
Since MADRIX 3.5 you will find a MIDI map for the Akai APC 40 MK II.
You only need to plug the USB connector to the desired PC and Windows will install the right driver. After Windows has recognized the APC 40 MK II and installed the driver correct you will find the APC 40 MK II in MADRIX and you can use the MIDI Mapping for the Akai APC 40 MK II.
