Can't load video file
bvanenk
Post by bvanenk »
hi,
I can't open video files with my Madrix 3.5.
When i open a file then i get an error in the midle of my screen. The message is effect video file S1 P50 L1 error loding video file.
Hoe can i fix this?
Thanks a lot, grtz!
Re: Can't load video file
Hello bvanenk,
It seems that you have not installed the right codec on your PC.
What format has the video?
If it is a Apple QuickTime movie please install the QuickTime codec pack:
http://www.apple.com/quicktime/
If it is another format of the movie please install one of the following codecs:
http://www.codecguide.com/
https://github.com/nevcairiel/lavfilters
bvanenk
Post by bvanenk »
Hi
Thank you for the reaction and the answer that you given was correct. Its works fine now.
Is it possible to merge two different patch files? I have 3 different shows. And I want to add an new fixture but this fixture is verry difficult to make. It is possible?
Gr. Bob
Regarding your question to merge two patch files, please see:
http://www.madrix.com/en/home/forum/vie ... 15/t,1283/
