Error message when closing Madrix in Windows 10
JasonCA
Post by JasonCA »
I have a brand new Acer laptop with a clean Windows10 install. No software, no adware, etc..
I put Madrix 3.5a on it and it works fine. But when I close Madrix, I get an error window that says "Madrix has stopped working".
It doesn't affect the program, it's just annoying when I go to shutdown.
Behavior the same with 3.6a
Intel i5-6200U
Nvidia 940MX
Re: Error message when closing Madrix in Windows 10
Hello JasonCA,
For a better issue analysis can you please send us a MADRIX logfile to info[at]madrix[dot]com?
To save the logfile please go in MADRIX to "Tools > Logfile", click the button "Save As..." and enter a name for the Logfile.
Occurs this issue everytime when you close MADRIX?
alternative you can watch at your home directory and there under documents/MADRIX3/logs if you find a error log.
JasonCA
Post by JasonCA »
After installing the Nvidia CUDA Toolkit the problem has corrected itself. I still sent you an email with my log file.
CUDA Toolkit can be found here: http://docs.nvidia.com/cuda/cuda-instal ... z4Hp1EtqH6
Hi, Jason, thx for the hint with the toolkit and the log file.
