problems of cuelist
problems of cuelist
hello,
can you help me?
I have two problems with cuelist
1. problem: cuelist and autostart.
I have set in option dialog for start,
ENABLE run MADRIX, when Windows start
ENABLE Load this setup on start
have selected my setup file "madstart.ms2"
ENABLE Start Cuelist after loading the startsetup
ENABLE Set Master Fader on value: 180
I have set storage place a16-a30 and b31-b45 with effects.
I go to Menu->Edit->Cue All Occupied Storage Places (a greatly function)
I open the cuelist select all items and set duration to 3 minutes
at the last item I set to follow cue to 1
I close cuelist and save setup to "madstart.ms2"
after i restart the computer
windows start
madrix start
cuelist button ||> is green, I think say it's run
the problem:
i don't see the effect from a16 because madrix select a1 and b1
at this time the output is black
after 3 minutes start effect a17
from there cuelist running fine
the place 1-15 are free in my setup, for using experiments,
don't want start from place 1 in cuelist
What can I do so thats a16 running at first time?
2.problem: cuelist and follow cue
Only I have changed the last follow cue in cuelist and i close MADRIX,
don't question comes that I ought to save setup.
it's thats right?
Last question:
How can i make a space line in this forum, or whats the BBCode of new line
can you help me?
windows start
madrix start
the problem:
it's thats right?
Last question:
Dear Dieter,
thank you very much for this bug reports (problem 1 and 2).
I can reproduce this behavior you describe and unfortunately i have to say,
yes this are bugs
Of cource we will fix it in the next release where the next beta will be available very soon.
For the 3.Problem i have no idea, we do not develop this Forum module
we just use it
yes this are bugs
I have found the new beta version and testing cuelist.
Okay, the problem are not available, fine.
Thanks.
But I have found another problem.
If cue list run and Madrix Skip to the second place in cue list, from there say MADRIX i must save the setup at end. I have not changed.
It's that allright?
Thanks.
It's that allright?
Hi Dieter,
thank you for testing the BETA and we are happy your last posted problems are fixed.
Because of the new one i want to say that is the reason why we publish a BETA first.
Did you use a macro or script on your second cue?
If yes this is the reason, because we changed some little things in the MADRIX script so we increased the version number (of the script). Therefor MADRIX have to compile the macro/script new which sets automatically the modify flag.
To avoid this for the next use just select all storage places with a macro/script and save the Setup after this. So this behavior will not occur next time.
