Error Code 10054
Dachsbau
Error Code 10054
Post by Dachsbau »
Hi everyone,
We are running Madrix 3.6g Basic on a Win10 PC.
I've just changed the connection to our art-net controller from a LAN-connection to a wireless connection (I now this is not ideal, unfortuneatly I don't have a choice)
Ever since i eep getting the Error Code 10054.
However, everything is still working fine, but of course I am afraid that this will change.
Is there risk that our setup will crash at one point? Or can I just ignore the error?
Thanks,
Fred
P.S.: The Log:
http://www.fast-files.com/getfile.aspx?file=149973
Re: Error Code 10054
Hello Dachsbau,
This issue normally occurs when the keep alive time of the opposite side (your connected Art-Net nodes or W-Lan router) will be to long and the host must be restarted.
Probably the W-Lan connection will get a timeout because of a hugh data rate which will be send via the W-Lan or the signal strength is too weak.
To use W-Lan for an Art-Net connection is not the best solution.
