Map settings - no negative number
qniens
Post by qniens »
In the map settings you can't type in a negative number directly in any of the field.
For example, if you want to change the Position X value to -50 you must first type '50'.
Then select with your mouse the value and enter a '-' symbol in front of it.
Re: Map settings - no negative number
Hello qniens,
Thank you for reporting this issue.
We can also reproduce the issue in the office and our developers will do the best to fix the issue as soon as possible.
