Network data output and Artnet issue
nascar45@aol.com
Im seeing broadcast traffic on the Ethernet nik as well as the normal data on my 'light-net' nik when useing ARTnet output. This doesn't happen when we use only streaming ACN????
Re: Network data output and Artnet issue
This depends entirely on your configuration of the software.
Art-Net can be sent in Broadcast Mode or in Unicast Mode. You can change that in the MADRIX Software for each Art-Net node/device.
It sounds as if you have set up Art-Net to broadcast into all networks.
sACN on the other hand, always sends in Multicast Mode.
