Save Madrix Set up file to SD card
gaminip1
Post by gaminip1 »
Dear Tech Team,
Please advise me how to Save Madrix programmed to SD card and Run the program thru SD card controller.
Regards,
Gamini Perera
Re: Save Madrix Set up file to SD card
Hello gaminip1,
Sorry, but it is not possible to save the MADRIX effects to a SD card to play it with a SD card player.
If you are looking for a DMX stand alone player, please have a look to the MADRIX PLEXUS. With the PLEXUS you are able to playback up to 2 DMX universes. If you need more than 2 DMX universes output, you can work with several PLEXUS in Master/Slave mode.
Under the following link you will find some more information about the PLEXUS:
https://www.madrix.com/products/plexus
gaminip1
Post by gaminip1 »
Hi Guertler,
Really thankful to you for the quick reply.
Regards.
Gaminip1
