Audio Input WDM or ASIO
I'm using Realtek High Definition Audio. I cannot use it as audio input even if i tried the ASIO installer. It says WASAPI: CaptureReadingWriteBuffer.... Can anyone help me?
Re: Audio Input WDM or ASIO
Hi maeish,
1) Please make sure that your sound card is able to use ASIO.
2) Is there a seperate software which has also access to the sound card?
3) Which is the audio source?
Here you can learn more about the audio configuration in MADRIX 5:
http://help.madrix.com/m5/html/madrix/h ... tsub=audio
I'm looking forward to hearing from you.
