Importing Libraries from Fixture Editor
RohanT
Post by RohanT »
Hi, I have created a fixture library but can find how to import int into the Patch.
Any suggestions?
Rohan
Re: Importing Libraries from Fixture Editor
Hello RohanT,
When you want to use your own created MADRIX Fixture Library, you have to load the library in MADRIX.
Therefor please navigate in MADRIX to "Preferences > Options". In the "Startup" tab of the "Options" you will find the setting "Load Alternative Fixture Library". Please enable it and choose the desired fixture library. After a click at the "OK" button the setting will be applied and the "Options" window will be closed. Now please restart MADRIX and you are able to patch the fixtures of the loaded fixture library.
