Is it possible?
billybowen
Is it possible?
Post by billybowen »
Hi everyone! It's great to meet you all.
So I have a question: Is it possible to create an X by Y matrix and then allocate individual LED strips to different parts of it?
I'm working on some partially filled displays and want to know if MADRIX 5 can handle it?
Thanks in advance!
Re: Is it possible?
Hello billybowen,
With the help of the Mapping you will be able to a assign a desired effect layer to be played only at a part of the the patch. Of course it is also possible to work with several effect layers which are mapped to different parts of the patch. Under the following links you can learn more about the mapping in MADRIX:
http://help.madrix.com/m5/html/madrix/i ... ialog.html
http://help.madrix.com/tutorials/m5/HTM ... pping.html
http://help.madrix.com/tutorials/m5/HTM ... e_gro.html
