Device FSP not being saved
Re: Device FSP not being saved
Hello billinsofl,
Thank you for the report. Can you please double check it again?
The set sending FPS of sACN interfaces are saved in the setup.
At the moment we can't reproduce it here in the office. As soon as we load a setup the sending rate of the sACN nodes will be set respectively reloded to the saved values
Hello billinsofl,
When I test it with the shared MADRIX setup I can't dedect the explained problem.
Can you please share or send via e-mail a screen recorded video which shows the issue at the used PC?
If you want to send it via e-mail, please send it to info[at]madrix[dot]com
