LED Fixtures With Extra Channels
Hello!
Here's my situation: I have several Chauvet Colorband T3BT that I need to patch, but in addition to RGB channels there are additional channels for dimming & FX. I need a way to keep the dimmer channels always at 255, but I'm not sure how to do this. Please send help!
Bonus question: I also have some other FX lights (kinta & swarm), is there a way to incorporate these? I would need to put limits on certain channel values.
Thanks in advance,
Eric
Thanks in advance,
Eric
Re: LED Fixtures With Extra Channels
Hi Eric,
You will need to create a corresponding fixture profile with the Fixture Editor. The dimmer channel needs to be set "Fixed" with a "Default Value" of 255 and the FX should be also "Fixed" with a value of 0.
You can build the fixture file yourself or you can send us the DMX chart to info[at]madrix[dot]com.
The following tutorials will teach you how to create fixture profiles with the Fixture Editor:
https://help.madrix.com/tutorials/m5/HT ... e_fix.html
https://help.madrix.com/tutorials/m5/HT ... ve_fi.html
- Fixture Editor_2.png (89.59 KiB) Viewed 2923 times
- Fixture Editor_1.png (89.61 KiB) Viewed 2923 times
