Cant make fixture
Cant make fixture
hi!
I have some ledbar`s from China, Longmangroup is the manufacturer.
But, i cant figure out how i can make the fixtures work with Madrix. I have give it a try but dont get it.
The bar has 22 ch, 3 pixel, red, green, blue, yellow and white. Here is the ch list:
ch1 random build in programs
ch2 dimmer
ch3 red all pixels
ch4 green all pixels
ch5 blue all pixels
ch6 yellow all pixels
ch7 white all pixels
ch8 red pixel 1
ch9 green pixel 1
c10 blue pixel 1
ch11 yellow pixel 1
ch12 white pixel 1
ch13 red pixel 2
ch14 green pixel 2
ch15 blue pixel 2
ch16 yellow pixel 2
ch17 white pixel 2
ch18 red pixel 3
ch19 green pixel 3
ch20 blue pixel 3
ch21 yellow pixel 3
ch22 white pixel 3
Can anyone tell me how to make this work?
If someone could make the fixture file to me it would be even sweeter!:D
Waiting for a great feedback;)
(if anyone make the file, it can be send to my email : arnechgjonvik (at) gmail dot com )
ch2 dimmer
ch3 red all pixels
ch5 blue all pixels
ch8 red pixel 1
ch9 green pixel 1
c10 blue pixel 1
ch11 yellow pixel 1
ch12 white pixel 1
ch13 red pixel 2
ch14 green pixel 2
ch15 blue pixel 2
ch16 yellow pixel 2
ch17 white pixel 2
ch18 red pixel 3
ch19 green pixel 3
ch20 blue pixel 3
ch21 yellow pixel 3
ch22 white pixel 3
Re: Cant make fixture
To create a fixture for MADRIX you can use the MADRIX Fixture editor.
1. Open The Fixture Editor
2. Open The MADRIX Fixture Library from the MADRIX folder.
3. Create Your Fixture
4. Save the MADRIX Fixture Library (of curse it is a good idea to make a backup before)
5. Start (Restart if allready run) MADRIX.
But in your case you can not get all colors of your fixture because MADRIX currently only support 4 Color LED´s.
This means you can use your fixture with MADRIX but you can only control 4 of your 5 colors. For one color (i think amber or white) you have to set up a fixed value (maybe zero) within the Fixture editor.
If you told me which color you maybe do not need and what kind of values you like for the first 7 channels i can produce the fixture for you.
hi and thanks for the reply!
If i cant use more than 4 colours , it will be RGBW.
If you can make the file i would be very happy.
Ch1 i guess i no need for madrix,just random shit.
ch2 is dimmer, i guess that should be 255?
the next channels that cover the hole bar, is that needed for madrix to run?if not just take them out to.
Rest of the ch list is in the first post:)
Would be very happy if you could make it, and send it to me by email after. the email is also in the first post .
-arne
-arne
hi man!
I did make it on my own
thx anyway
