Getting digital sound in from PioneerDJ CDJ setup?
r2.lighting
How do I get digital audio in to control S2L and M2L effects in a PioneerDJ/CDJ or AlphaTheta/XDJ setup?
Re: Getting digital sound in from PioneerDJ CDJ setup?
Hello r2.lighting,
The easiest way would be to connect the audio interface input of the used MADRIX PC with an additinal audio output of the used DJ console.
If you want to use a digtial connection you would need to find a kind of "virtual converter" software which converts the digital audio stream from the DJ console into an audio stream which MADRIX can interprete.
These software would need to be recognized like a audio interface.
