Aura recorded scenes not playing on my pixels
UpLighting
So I foolishly deleted the default scenes before testing my new ones.
I have an Advatek controller attached to my Aura. The default scenes played perfectly fine. I was able to record cues onto the Scene (after deleting all the existing ones). They are now not playing on my pixels. I switched the Advatek between sACN and Art-Net with no success (it was working on sACN). I have it set to send out starting Universe 1 to the Madrix Aura. I disabled my remote control so I don't risk conflicting universes.
Aura Network Playback Settings are sACN, starting at U10, which lines up with the Aura Network Recording Settings.
What the heck am I missing? And is there a way to get back those original scenes so I can test that benchmark?
UpLighting
Re: Aura recorded scenes not playing on my pixels
Quick updated / extra note: The "Highlight" function under "Network Playback Settings" works to light up the correct strings.
Hi UpLighting,
Did you use MADRIX 5 to record the scenes? Please send us the MADRIX 5 setup and the files from the AURA SD card to info[at]madrix[dot]com.
Here you can download the default scenes:
https://www.madrix.com/download/aura/MADRIX_AURA_Presets_RGB.zip
Thanks in advance!
Thanks in advance!
UpLighting
Yes, I used the "Rec" function from Madrix 5 to record to the Aura. I made cues into a playlist, and told Madrix to record those cues to the Aura. I will work on getting those files off to you, and thank you for the zip folder!
