Cuelist - Mix of manual and automation
Mattlightd
Post by Mattlightd »
Hy everyone,
I got an issue with cuelist edition:
I am operating a cuelist manually, with 'GO' or 'GOTO' arrows, cue after cue.
But some cues are programmed with durations. The following cue is efficiently running after, but the next 'GO' after such an automation will bring me back at the first cue of the list :(
I already tried to force it indicating a number as 'next cue' in the sequence, but it still does not work.
Any idea ?
It seems like everything has to be manual, or everything with durations, but not a mix.
Re: Cuelist - Mix of manual and automation
Hello Mattlightd,
At the moment a Cue List is not pausing after a Cue with duration was played. It calls the next Cue and will stop. If you now call the "Go" command again, it will start from the beginning (because the Cue List was stopped).
At the moment you can prevent the behavior with the little Main Output macro which is attached.
PauseCueListAfterPlayback.zip
(485 Bytes) Downloaded 56 times
Simply download and unzip it. To load a Main Output Macro simply perform a right click at the Main Output Macro button in MADRIX and select open.
