reaper marker
yahavt@gmail.com
reaper marker
Post by yahavt@gmail.com »
I'm trying to insert markers from REAPER into a cue list and I can't. Has anyone succeeded before? Can you explain where I'm going wrong?
Re: reaper marker
Hello yahavt,
Before you export the Markers in Reaper please make sure the Timeline is set to the format "Hours:Minutes:Seconds:Frames". To change these settings simply perform a right click at the Timeline in Reaper and select the desired setting.
If no markers are added in the project you can now add the markers.
After the markers are added simply open the "Region/Marker Manager" in Reaper (View > Region/Marker Manager), perform a right click in the manager and select "Export regions/markers".
In MADRIX you can now append the list of markers in the Cue List.
Therefor a Cue List needs to be exist. If no Cue List already exists, simply click the "Edit" button (Pen) and add a new Cue List. Now please navigate and click the "File" button in the Cue List. In the Context menu please select "Append Cues From Markers...", select the exported Reaper file and click "Open".
The Markers will now be imported as separate Cues in the MADRIX Cue List.
