Swapping Timeline between Deck A and B?
I have playback speeds set differently between Deck A and Deck B. I made a timeline with Deck B apparently, but want it to point at Deck A so I can have that playback speed.
How do I swap? I can see how to change the Storage and Place, but it stays in the same Deck.
Re: Swapping Timeline between Deck A and B?
Hello Avocado,
By default MADRIX choosing the Playback side after calling the desired "Storage Places" of a "Timeline" or "Cue List" by Storage ID Parity. That means all "Storages" with Odd numbers will be played at Deck A and all "Storages" with Even numbers will be played at Deck B.
If you want to change the Playback Side of the desired "Timeline", you have to copy the full Storage (right click at the "Storage Number Button" and select "Copy" in the contex menu).
To play the timeline later on Deck A, you have to select a "Storage" with Odd number and "Paste" it.
At the generated Timeline you have to select all "Cue Segments" and change only the "Storage" number to the used Odd Stroage number.
Now the Timeline will call the effect at Deck A.
