combining remote commands
steve@eoslightmedia
Is there a way to combine remote commands?
For example, I would like to combine commands like:
http://10.10.155.141/RemoteCommands/SetLayerA=2
http://10.10.155.141/RemoteCommands/Set ... pacity=255
Is there a formula I can use to combine several commands?
Re: combining remote commands
Hi Steve,
I want to quickly inform you that the answer might take two more days. We will post a reply as soon as possible! Thanks.
steve@eoslightmedia
thanks for looking in to this --
I am onsite programming now.
Hi Steve,
We had hoped to simply combine the two with an "&" command, but it is not possible. Even if it would be that simple, we would run into a much more severe problem. And that would be the missing priority settings. What I mean with that is that even though Opacity might be called as second funtion, it could end up being the first function called, because one function does not have a higher priority than the other function.
