Matrix 14x14 pixels ws2801
hi everyone,
have made a screen that is
1.2m x 1.2
it has 14 x 14 pixels on them. Wired in a snake pattern from bottom left.
The pixels are split over 2 universes.
I am using an ECG-p2 controller. Using artnet.
Im having issues though. When i patch the first half of the pixels, all is okay. Screen works fine.
When i patch the second half they dont respond accordingly.
When i highlight a pixel, it lights up 2 pixels with different colours? like the channels arent layered properlly?
any ideas/solutions to this?
thanks-
1.2m x 1.2
thanks-
Re: Matrix 14x14 pixels ws2801
Sounds like a wrong patch either on the software side or on the hardware side.
You should double check if you have assigned universe two inside MADRIX for the second half of RGB Pixel. If this works well you should double check the settings of your node and or pixels/fixtures.
