startup with last setup
Do you think you could offer the option to start Madrix with the setup that was loaded last?
Re: startup with last setup
Hi cg,
MADRIX already features a similar option. It is called "Load This Setup On Start" and you can find it in the Start Options (Preferences > Options... > Start Options). Simply choose the Setup you wish to load every time MADRIX starts.
sorry, no - that is not what I asked for. This always loads one specific setup.
I would like to have the option to have the setup loaded, that was in use when Madrix was closed.
Could you please describe the situation in which such a feature would be useful to you?
There might be a template that has all general stuff in it. Then for a showday I load that template, "save as" with a new name and do some programming specific to that show. In the evening Madrix would automatically load that specific showfile.
Or I do some programming at spare time and there is an interruption. After an hour or so I start Madrix again and can go on where I left...
it will work you you save your changes at the same setup file you have entered in the options dialog
