library Clay Paky
library Clay Paky
You can get the library to Clay Paky A_Leda_K10
Re: library Clay Paky
Hi LD,
currently we did not include moving head fixtures to our library to avoid the missunderstanding people think MADRIX is made for controling moving heads as well.
Because of the fixture editor we think it is possible to use such fixture with MADRIX in cases where a DMX merger is used for controling the color by MADRIX and the movement by a different application. For example is this possible with the MADRIX Luna using Art-Net.
But you are not the first person which ask for and we realize it is mostly about LED moving heads.
So we are thinking about to change this rule depending on how much more requests we will get.
@All
Which LED moving head fixtures you are interested as well in the MADRIX Fixture Library?
@All
Hi LD,
Please check the fixtures in MADRIX 3.0a. Thanks!
