fixtures losing their addresses
triggerhappy
hiya
i've just finished setting up a system with 48 chauvet colorband pix mini fixtures and they're having some sporadic faults. i don't think it's Madrix's "fault", but perhaps someone here will have some suggestions for troubelshooting!
the the problem is that the fixtures run fine for a while, but sometimes lost their dmx address for a nearby address. i.e., a fixtures set to dmx id 37 will after a while reset itself to eg 35 or whatever.
it seems like the fault must be with the fixtures... BUT it only happens running them off Madrix via two USBone dongles, i can send dmx to them from Chamsys using an Enttec DMX pro 2, and they behave fine.
if anyone has experienced anything similar, i'd value some advice!
thanks in advance.
thanks in advance.
