Madrix 3 for Neo
viktorcordero
Madrix 3 for Neo
Hello, I have a Madrix Neo in which I connect to the Madrix 5 and the key does not activate, I have read that I need the Madrix 3, where can I download this version to be able to use my Neo? or if I can use the Madrix 5, could you help me?
Thank you
Thank you
Re: Madrix 3 for Neo
Hi viktorcordero,
Welcome to the MADRIX forum!
The MADRIX NEO enables the data output for MADRIX 3. If you want to use MADRIX 5 you will need a MADRIX 5 license, for example a MADRIX 5 start license.
If you send us your MADRIX NEO serial number via e-mail to info[at]madrix[dot]com we can send you the download link for MADRIX 3.
Please note that the software support and project support for the MADRIX 3 series has ended on May 07, 2020.
