need scripting help
need scripting help
I will build a effect script with an min and max slider for build a range. What I must do? Value for min are never higher then max value and max value never lower then min value automatic.
How program that?
Here my not perfect script test.
Can anyone help me?
How program that?
Code: Select all
@scriptname="SliderMinMaxRange";
@author="Dieter";
@version="1.0";
@description="11/14/2011";
int maxX=GetMatrixWidth();
int maxY=GetMatrixHeight();
ctrlslider sliderMin={"Min",1,maxX*1/4,maxX};
ctrlslider sliderMax={"Max",1,maxX*3/4,maxX};
void InitEffect(){
// get size
void RenderEffect(){
Clear(); // clear screen
// get value of slider
int maxValue=sliderMax.value;
int minValue=sliderMin.value;
// check range
if(maxValue<minValue)maxValue=minValue;
if(minValue>maxValue)minValue=maxValue;
// set value of slider
sliderMax.value=maxValue;
sliderMin.value=minValue;
// draw rectangle
FillPixelRect(WHITE,0,minValue-1,maxX,maxValue-minValue+1);
DrawPixelRect(RED, 0,minValue-1,maxX,maxValue-minValue+1);
void MatrixSizeChanged(){
InitEffect();
Re: need scripting help
try this
Code: Select all
@author="Dieter";
@version="1.0";
int maxX,maxY;
ctrlslider sliderMin={"Min",1,100,100,"Min"};
ctrlslider sliderMax={"Max",1,100,100,"Max"};
void InitEffect()
// get size
//Init Slider ranges
int sMin = (int)((float)maxY*0.25);
sliderMin.rangeMax = sMin;
sliderMin.value = sMin;
int sMax = (int)((float)maxY*0.75);
sliderMax.rangeMax = sMax;
sliderMax.value = sMax;
void RenderEffect()
//check range
if(sliderMax.value < sliderMin.value) sliderMax.value = sliderMin.value;
if(sliderMin.value > sliderMax.value) sliderMin.value = sliderMax.value;
// draw rectangle
FillPixelRect(WHITE,0,sliderMin.value-1,maxX,sliderMax.value-sliderMin.value+1);
DrawPixelRect(RED, 0,sliderMin.value-1,maxX,sliderMax.value-sliderMin.value+1);
InitEffect();
Hi wissmann,
sorry but you don't understand my problem.
I don't will limit the range of slider or output.
I want:
If I slide the max slider lower the min slider then also move the min slider lower.
If I slider the min slider higher the max slider then also move the max slider higher.
If you test my script you see one direction running fine but the inverse way running not really good.
I want:
Hi dieter,
maybe this is what you are looking for.
Code: Select all
@author="Dieter";
@version="1.0";
void InitEffect(){
// get size
int newmaxValue=maxValue;
int newminValue=minValue;
// check range
if(minValue>maxValue)newmaxValue=minValue;
if(maxValue<minValue)newminValue=maxValue;
sliderMax.value=newmaxValue;
sliderMin.value=newminValue;
// draw rectangle
FillPixelRect(WHITE,0,minValue-1,maxX,newmaxValue-newminValue+1);
DrawPixelRect(RED, 0,minValue-1,maxX,newmaxValue-newminValue+1);
InitEffect();
