Aura Group Control
CoolB
Aura Group Control
Post by CoolB »
I have 6 groups on the Madrix software that I'm able to control group intensity FROM 0-255 with an Orion and a switch. I'm trying to set this up on the Aura to do the same but I have had no luck in getting it to work the same with the group settings. Really could not make any sense of the settings in the manual with the SD card. Any help would be appreciated to get me on the right track.
Re: Aura Group Control
Hi CoolB,
Hi AllanPeter,
Sorry for the delay in answer!
The 'Fixtures Groups' in MADRIX 5 are not the same as the 'Intensity Groups' for the MADRIX AURA.
The intensity groups refer to the so-called 'Channel Mask', which allows you for example to control specific channels of a universe using the eight intensity groups.
That means to achieve the intended behavior you will need to create your own customized Channel Mask. The Channel Mask is basically an .xml file (ChannelConfig.xml), which is saved on the SD card of the AURA
Here you can learn how to create the Channel Mask and how to use it:
https://help.madrix.com/aura/html/hidd_ ... _mask.html
I hope this helps you!
4Matthew
Post by 4Matthew »
Hello @Schulze,
Thanks for the link, it helps me a lot.
