Freezes under startup
Nordbek
Post by Nordbek »
Hi
I just indtalled version 3.2.
But it freezes with the splash screen open.
It says:
Set first 116 log entries for static log
And it just stays there.
How to move on?
zeighty
Re: Freezes under startup
Post by zeighty »
Did you determine the cause?
Hello zeighty,
This issue was discussed by e-mail and we send Nordbek some approaches. But we did not receive an answere.
Have you also such a problem?
zeighty
Post by zeighty »
Thanks for the follow up. Sorry I lost track of this post.
I did have a "freeze" situation, but my computer was completely frozen not just Madrix. It may have been heat related (laptop was sitting on a towel). It has only happened twice and I was running Madrix both times.
If it happens again, I will respond.
Thanks again!
Z
dfk
Post by dfk »
I'm having the same issue with v3.x on my laptop (HP 8570W LY552ET running Win7)
v2.14g works as expected.
In my case its not caused by overheating hardware, I can run v3.x using VMware on the same machine.
Any idea's?
EDIT:
Updating the NVidia drivers solved the issue.
