Glitch and unstable flashes
santanas-savannahs
Post by santanas-savannahs »
Hi I have a Eurolite custom Made DVI curtain 64 long by 80 led wide and I used Genaric 1 RGB set to 80 by 64 and after T9 is good try to use and it glitches on top 1 or 2 rows of curtain and makes pattern jumpy? have reste software 2 times using Windows 7 ro on computers laptop and Desktops with Pro video cards. loosing my mind? Any Ideas? :oops: :(
Re: Glitch and unstable flashes
Hello santanas-savannahs,
We are sorry that you are experiencing this issue.
The problem occurs when MADRIX 3.4 is connected to a T9 LSD AIO controller with firmware version 15.15.
It will be fixed in the next MADRIX version (MADRIX 3.5).
To avoid this issue until the new MADRIX version is released, please use MADRIX 3.3b:
http://www.madrix.com/download/MADRIX_F ... l_3_3b.exe
santanas-savannahs
Hi. Thanks for the reply, was told to use the 3.3b version, Now works with out a glitch. We are fine for now. Thanks :D
