8 bit RGB Color using 1 channel
snipermand
Im really not sure if it's possible with the current release, but it would be nice with a feature of generating RGB colors using only 1 channel.
bit 7 6 5 4 3 2 1 0
color R R R G G G B B
In this way it is possible to drive upto 512 RGB pixels in one universe.
Regards Peter
bit 7 6 5 4 3 2 1 0
Regards Peter
Re: 8 bit RGB Color using 1 channel
Hi snipermand,
no actually this is not possible.
I agree in the case it is possible you are able to control 512 RGB pixel but on the other hand did you have an idea about how it looks like?
I mean for blue for example this means only 4 different intensity levels (one out, one full on, two inbetween) and for red and green this are just 8 differnet intensity levels.
In what kind of application did you mean make this sense? (No worry i really interested in your answer).
The opinion of other users i really would appreciate as well !!!!
snipermand
To display graphics and not pictures, i would think 256 colors would be sufficient.
Please take a look on the different palettes using only 8 bits:
http://www.stevechamberlin.com/cpu/2008 ... tte-setup/
I'm working on a dancefloor of 500 RGB LED's (20 x 25) and it would be nice if i could drive it using only 1 universe.
I understand this would limit me to only 256 colors, but for the purpose of a lighting dancefloor, i think this is sufficient.
A choice of different kinds of 8bit palettes would be nice, but i think the RRRGGGBB palette would be the easiest to incorporate in the software.
Maybe the palette RRGGBBSS would give the best result.
Hi snipermand,
why do you not write a macro for your fixture to manipulate dmx values.
I think it's simply when use functions like this:
It's easy to write a macro with madrix.
I think the right place is the main output macro to transform your own dmx values.
Code: Select all
GetPixelArea(MATRIX) - get dmx matrix
MATRIX[heigth][width]=R*32+G*4+B -transform data for fixture RRRGGGBB
DrawPixelArea(MATRIX) - write dmx data screen
Hi snipermand,
ok the idea is right but the script not so simple I think.
I have tested out to write a script.
I think have a script for your problem, but I can test it without fixture.
My dmx tester say the values are rigth for your fixture in RRRGGGBB mode.
This script have 2 problems thats I have see:
1. the output screen is distorts, but can use preview screens left and rigth
2. the master fader can't be use, must all times set by max value (255)
I have test this macro only with one universe and generic RGB fixture with size 48*32
Here the script:
check it out and get feedback it's running or not
Here the script:
Code: Select all
@scriptname="video palette fixture";
@author="dieter";
@version="MADRIX 2.8";
@description="main out macro, special for video palette fixture";
int H=0,W=0,R,G,B,C=0;
color MATRIX[][];// data of matrix
color CHANNELS[];// dmx channels
int LEN;// value for length of channels
void InitEffect(){
W=GetMatrixWidth(); // get current matrix size
H=GetMatrixHeight();// get current matrix size
C=GetColorDepth(); // get current color depth
if(C!=3)// I have only testing with generic RGB fixture
WriteText("I have not testing with different colordepth not equal 3");
void PreRenderEffect(){
void PostRenderEffect()
GetPixelArea(MATRIX,0,0,W,H);// get color values of matrix
for(int w=0;w<W;w++){
for(int h=0;h<H;h++){
CHANNELS[h*W+w]=MATRIX[w][h];}} // transform matrix to an array
// render new DMX value to array, use RGB and build user define DMX value
LEN= CHANNELS.length;
for(int i=0;i<LEN;i++){
R=CHANNELS[i].r/32;
G=CHANNELS[i].g/32;
B=CHANNELS[i].b/64;
switch(i%C){// summary RGB to 1 channel color palette
// switch pallete to single channel
case 0:CHANNELS[i/C].r=R*32+G*4+B;break;// RRRGGGBB
case 1:CHANNELS[i/C].g=R*32+G*4+B;break;// RRRGGGBB
case 2:CHANNELS[i/C].b=R*32+G*4+B;break;// RRRGGGBB
case 3:CHANNELS[i/C].w=R*32+G*4+B;break;// RRRGGGBB
for(int i=LEN/C;i<LEN;i++)// unused channels set to black
CHANNELS[i]=BLACK;
MATRIX[w][h]=CHANNELS[h*W+w];}} // retransform array to matrix
DrawPixelArea(MATRIX);// write values back to matrix
void MatrixSizeChanged(){
InitEffect();
snipermand
Thanks Dieter for your reply.
I will try out your script as soon my fixture is finished.
If you script works then i will only need 1 universe to control my a matrix wall of 32 x 16 pixels and not 3.
I was wondering how do the manage these large walls? are they using controllers with many universes to control many segments.
Thanks again for your effort.
VR Lighting
I'd get 2 more NEOS so that you have 3 in total (1per universe), i think it's worth the investment if you really want to take full advantage of the installation.
VR Lighting
or try changing the address so that it wont use more then one universe.
