Make a scrolling with simple shape
mookai1973
Hi.
How to made a scrolling effect from top to buttom with simple shape?
Thank you so much
Thank you so much
Re: Make a scrolling with simple shape
If I understand correctly, you could create this animation using the Effect Parameter Chaser. Make sure to select 'Layer Map Settings' as Parameters, place the shape up top > Add Step, then place the shape at the bottom > Add Step, and set up the Fade Time:
http://help.madrix.com/m3/html/madrix/h ... haser.html
