Custom User Profile won't load
mercury2768
I found a bug. Please take a look: https://youtu.be/uLrF-PAnOus
I am trying to create a custom profile and I could not get it to load. This was recreated by another user on the facebook group Madrix @ Work.
Re: Custom User Profile won't load
Hello mercury2768,
The current behavior of MADRIX is not a bug.
Of course you have add 7 remote functions in the remote Editor but you didn't change the DMX channel assignment for the last entry. It is still set to DMX Channel 1.
That means with DMX Input Channel 1 you will control the Master and also the Submaster of Deck B remotely.
If you change the DMX Channel of line 7 to the desired DMX channel for instance to 7, you will be able to control the functions seperately.
There is no automatic counting of the DMX Channel mapping because it could be a wanted behavior to control several functions with one and the same channel remotely. Furthermore you are able to assign the functions non linear.
