Can Madrix connect several large scenes over the network?
邓秋波
Post by 邓秋波 »
For example, several buildings are far apart, how to operate to synchronize their effects.Is there a video tutorial?Thank you for your attention
Re: Can Madrix connect several large scenes over the network?
Hi 邓秋波,
Yes, MADRIX 5 supports a lot of well-known industry standards for the data output (for example Art-Net, sACN, DMX512, DVI).
In order to cover large distances , Ethernet based communication protocols such as Art-Net are sACN are often used, which are supported by MADRIX 5. Both Ethernet protocols allow you to transfer DMX data over an Ethernet network.
Here you can find the different MADRIX licenses and the maximum possible data output for each license (part MADRIX 5 Licenses):
https://www.madrix.com/products/software
Additionally here you will find more information about the data output capabilites of MADRIX 5:
http://help.madrix.com/m5/html/madrix/hidd_output.html
Simply create your own individual patch with the MADRIX Patch Editor and map your favourite effects on it. That means with the help of the "Mapping" function, you can assign different MADRIX Effects to different areas of your LED installation (and also different fixtures). Of course, you can also map MADRIX Effect on the complete virtual LED matrix and therefore on the complete LED installation.
Learn more:
http://help.madrix.com/m5/html/madrix/h ... ialog.html
If you need further assistance, you can also write us an e-mail to info[at]madrix[dot]com.
