'Fade' option on all effects
steve@eoslightmedia
It would be great to have the 'Fade' toggle option on more effects. It would increase the ability to use more effects in architectural applications.
Re: 'Fade' option on all effects
Hi Steve,
i am affraid i am not realy sure what you mean.
Can you explain more detailed what you mean with Fade toggle option please.
steve@eoslightmedia
Sorry for my vague post -- I am referring to the 'Fade' toggle switch on the Color Scroll effect for example that mixes the colours together rather than hard edges. This feature also allows lights to gently 'fade in' rather than 'snap on'. The feature is a better way to integrate effects into architectural applications.
let me know if that makes sense.
Ok, thank you, now i understand.
And which other effects you like to have this feature as well?
steve@eoslightmedia
ideally, it would be nice to have an edge fade to adjacent colours and to background to all effects. Similarly, an opacity/transparency slider would be very useful as well.
Also, Thanks for following up on my requests. We are planning on using Madrix quite a bit on upcoming proposals.
An opacity slider for each layer allready exists left to the blind and solo Buttons or right to the effect drop down box
