Count
acrogenesis
Count
Hello i'm really new to all this and i need some help understanding how to setup the Matrix Generator. I choose the lamp i have "American DJ Mega Pixel Led 28 Channel" but in count what am i supposed to enter? Does it change if I put the bar standing up or just on the floor? Another question i have is how do i setup madrix to control the bars different by these i mean in the "lower" bar lets say i want only blue but in the "top" bar i want red. Up to now i have only been able to do it symmetrically.
Re: Count
Ok, let us split your questions.
1. Count
here you have to enter how many fixtures you want to use in x and y.
Just for an example if you have 10 pieces of you fixture right beside each other
a count of 10 in x and a count 1 in y make sense.
If the fixtures are above each other 1 for x and 10 for y make sense.
now the Matrix Generator will create the patch for you.
In the seond example you will get a matrix form 8 x 10 pixel because one American DJ Mega Pixel Led 28 channel provide 8 RGB Pixel.
2. Different colors on different LED Bars.
The simplest way would be to choose the SCE Colorramp Effect and setup the colors and directions as needed. Just test it.
I hope this helps.
1. Count
I hope this helps.
